Removing Debug Code from CodeWarrior with HC12
Question asked by Gabriel Figueiredo Horta de Siqueira on Sep 29, 2008
Latest reply on Sep 30, 2008 by bigmac
I am trying to remove all debug code from my build. I am using CodeWarrior 5.7.0 with MC9S12E64.
When I set the option "Output/ don't generate debug information" in the compiler options.
The linker gives me the message "File star12.c.o should contain DWARF information".
I am also setting the option "Output/ ELF/DWARF:strip simbolic information", and there is no problem with it but I am not sure if this is enought  to remove all debug code.
I am having space problems and I am trying to remove all the unused code that I can.
I'll apreciate any suggestion.
