How does PN532 rewrite the problem of block 0 in the UID card 0 sector
礼伟曹
Hello,PN5321A3HN/C106 how to rewrite the operation steps of block 0 in UID card 0 sector,
Is there any relevant driver code?
Thank you!
IvanRuiz
This is the first data block (block 0) of the first sector (sector 0). It contains the IC manufacturer data. This block is programmed and write protected in the production test for which it cannot be modified.
Ivan.
