How to test bluetooth A2DP profile in L_4.9.11?
deven_solanki
I have been working on iMX7D-Sabresd board with "NXP i.MX Release Distro 4.9.11-1.0.0 (morty)". I want to test bluetooth A2DP profile with this kernel. I already tested with kernel 4.1.15 and it's working fine. But in kernel 4.9.11 it is failing.
Here I attached the procedure which I used in 4.1.15.
Can you please provide me steps to check A2DP in bluetooth ?
Thanks in advance,
Deven Solanki
diegoadrian
In this case, you need to go with the provider of your Bluetooth device. So, they can provide you with the correct driver for the new kernel version.
Diego.
