Jeongtae Park
Stall Error occurred
Discussion created by Jeongtae Park on Nov 21, 2017
Latest reply on Nov 24, 2017 by Matej Pacha
Using MC9S12ZVML128_BLDC_Sensorless S/W, I tested BLDC motor by own board.
Stall error was occurred when there is load on BLDC motor.
Please refer to the attached.
stall check function is as below.
void StallCheck(void)
           tU16 max = 0, min = 65535;
           if (periodZC_F_PhA>max){
                      max = periodZC_F_PhA;
           if (periodZC_F_PhA<min){
                      min = periodZC_F_PhA;
           if (periodZC_F_PhB>max){
                      max = periodZC_F_PhB;
           if (periodZC_F_PhB<min){
                      min = periodZC_F_PhB;
           if (periodZC_F_PhC>max){
                      max = periodZC_F_PhC;
           if (periodZC_F_PhC<min){
                      min = periodZC_F_PhC;
           if (periodZC_R_PhA>max){
                      max = periodZC_R_PhA;
           if (periodZC_R_PhA<min){
                      min = periodZC_R_PhA;
           if (periodZC_R_PhB>max){
                      max = periodZC_R_PhB;
           if (periodZC_R_PhB<min){
                      min = periodZC_R_PhB;
           if (periodZC_R_PhC>max){
                      max = periodZC_R_PhC;
           if(periodZC_R_PhC<min){
                      min = periodZC_R_PhC;
           periodZcAvrg = period6ZC / 6;
           if((max > (periodZcAvrg << 1)) || (min < (periodZcAvrg >> 1))){
                      if (stallCheckCounter < STALLCHECK_MAX_ERRORS){
                                  stallCheckCounter++;
           }else{
                      if (min < STALLCHECK_MIN_CMT_PERIOD){
                      }else{
                                  if (stallCheckCounter > 0){
                                             stallCheckCounter--;
           if(stallCheckCounter >= STALLCHECK_MAX_ERRORS){
                      StallError = 1;
           }else{
                      StallError = 0;
Would you provide solution for this issue?
Thanks.
