We find two codes of L-SDK(17.09).
- flexbuild_lsdk1709_update_103017.tgz
- flexbuild_lsdk1709_092917.tgz
We want to know these differences.
Could you advise following questions?
Q1. Please let us know the difference between "flexbuild_lsdk1709_update_103017.tgz" and "flexbuild_lsdk1709_092917.tgz".
=> We guess that difference is LS1012ARDB supporting, or not.
Is our guess correct?
If possible, could you provide the document for "lsdk1709-update-103017"?
Q2. Please let us know the difference between " fsl_fman_ucode_ls1043_r1.1_106_4_18.bin" and " fsl_fman_ucode_ls1043_r1.1_108_4_9.bin ".
Thank you for your reply.
Please let me ask further about Q2.
(The original Q2 may not be clear, sorry.)
From Section 4.6.2.7 of LSDK 1709 documentation, we understand that the version of FMan microcode and the version (/revision) of LS1043A need to match.
Usually, we think that the latest FMan microcode should be used.
In the meantime, if revision of LS1043A is old, the latest FMan microcode may not match.
In this case, we may need to get to know the version of corresponding FMan microcode.
How can we know this?
Q1. The flexbuild_lsdk1709_update_103017.tgz is update for the LSDK1709. A few mistakes are fixed in this update.
The LSDK supports LS1012a. See LSDK 1709 documentation:
https://www.nxp.com/docs/en/supporting-information/LSDK-KC-REV0.pdf
Q2. Look at the Section 4.6.2.7 of LSDK 1709 documentation.
Pavel Chubakov
