Tony Garland
No Connection Provider for PBL Component for LS1012A
Discussion created by Tony Garland on Nov 17, 2017
Latest reply on Dec 13, 2017 by Tony Garland
I was following the instructions for generating a PBL configuration for the LS1012A using QCVS within CodeWarrior 11.2.5
Whenever I click on the PBL:PBL component, the following error dialog appears:
When I look at the contents of the target_access_settings.xml file (/usr/local/Freescale/CW4NET_v2017.03/Common/QCVS/Optimization/resources/QorIQ/common/config/target_access_settings.xml), it appears that some targets include a targetAccessName value whereas others do not. The entry for the LS1012A does not.
Is this a problem? Should I modify the target_access_settings.xml file to mimic other entries?  Is this due to not having an active JTAG (TAP) connection?
I'm able to successfully generate a PBL.bin output file--but am not sure what to make of this error?
