CMSIS driver I2C, support for DMA?
Question asked by Gunnar Bohlen on Nov 14, 2017
Latest reply on Dec 17, 2018 by jeremyzhou
I'm writing code for LPC54618.
I want to use the CMSIS drivers for I2C, SPI and USART that I can find in the SDK.
File name that I found in the SDK_2.2_LPC54618J512 is "fsl_i2c_cmsis.c", unfortunately I cannot find a file version number in this file ...:-(
If I set in RTE_Device.h
#define RTE_I2C0 1
#define RTE_I2C0_DMA_EN 0
I2C0 is working as expected.
If I set
#define RTE_I2C0 1
#define RTE_I2C0_DMA_EN 1
I2C is not working. E.g. I see that in AHBCLKCTRL the clock for DMA is not enabled.
I see in the initialization for SPI :
case ARM_POWER_FULL:
   if (!spi->status.isPowerOn)
          /* Enable flexcomm clock gate */
           CLOCK_EnableClock(s_flexcommClocks[spi->resource->instance]);
           /* Init DMA */
but I cannot find the equivalent code in i2c code.
Could anyone give me an advice how to get the DMA working for i2c?
Thank you.
