Precautions to avoid S32k devices getting secured
ummerkunnummalk
How do we make sure that the flash configuration field is not getting erased/ updated unwantedly, resulting in the device to be permanently secured.
Basically I would like to know any precautionary steps which we can follow to avoid situations where the device gets secured permanently.
ev1
I'm facing the same problem. Have you solved? Thanks in advance
