FRM-KL26z USB host: ID pin connection
Question asked by Ravi Teja Gudapati on Nov 14, 2017
I would like to use FRDM-KL26 board as USB host. In the user guide (FRDMKL26ZUG), it says that
- Jumper J9 shall be connected to get power out of FRDM board in USB host mode
- Resister R8 shall be shorted.
My question is, about shorting R8. I don't see that KL26 uC has a USB0_ID pin. In the FRDM-KL26 board, I don't see that ID pin (TO_USB_ID_TP) is being connected to an USB_ID pin in uC. So, is this even required?
If I connect a USB memory stick on the other side, which will never act as USB host, cant i just manually set USB peripheral in USB host mode?
Thanks!
