IFC chip select algorithm
Question asked by Faiz Majeed on Nov 14, 2017
Latest reply on Nov 14, 2017 by ufedor
What is relation between 24bit base address in IFC registers and 24bit base address in Local Access window registers.
These are two addresses that are compared during chip select algorithm as discussed in Address Masking Register?
do i have to create different Local access window for each chip select of IFC?
I am not getting the idea that how processor will enable chip select by using IFC registers base address and Local Access window registers. I think reference manual contain limited information about address translation.
Also suggest me some documents which help me to understand whole memory mapping process used by T1042 specially for IFC.
Processor i am using : T1042
