Yocto - Add functionality without recompiling all kernel - (modules ?)
Question asked by Maxime Dutres on Nov 14, 2017
Latest reply on Nov 15, 2017 by Carlos_Musich
I'm currently working on i.MX28 with a linux kernel generated by Yocto project.
I noticed that I can activate some functionnalities of kernel with this specific config file :
meta-*****\recipes-kernel\linux\linux-fslc\mxs\defconfig
For example, I've changed
# CONFIG_CAN_BCM is not set
to
CONFIG_CAN_BCM=y
I recompile linux kernel with following command
bitbake -C fetch virtual/kernel
and it activates BCM protocol for CAN bus.
I would like to know if it is possible to add this BCM protocol without recompiling all kernel.
I've heard kernel modules could do that, but I'm totally novice to that.
Thank you in advance if you could help me.
