Thanks, I believe those to be effective!
However, I think "cmdide.exe" is more directive and easy-understanding.
Hello
There are different ways of automating build process for multiple projects.
You can use Microsoft COM automation from a Perl or Visual Basic Script. Please refer to {Install}\Help\PDF\IDE_5.7_Automation_Guide.pdf Chapter "Microsoft COM Automation" for more information on that.
You can use use a TCL script instead to do that.Please refer to {Install}\Help\PDF\IDE_5.7_Automation_Guide.pdf Chapter "Command Window Scripting" for more information on that.
CrasyCat
Message Edited by trotin on
2008-10-06 02:23 AM
