about i.MX6 PCIe cache coherency
masamiyasui
In i.MX6Q PCIe End Point,  if cache is enabled  in the inbound area, I think that cache invalidate is necessary before and after writing from Root Complex to this area.
How can End Point know the timing of these cache invalidate?
Without these cache invalidate, End Point could not read the data which Root Complex wrote to this area.
Labels (2)
Tags (3)
Yuri
  I.MX6 does not support cache coherency (in hardware). Therefore it
may be recommended to configure the PCIe memory area as non-cached,
if several bus masters can access it.
Yuri
masamiyasui
Thank you very much for your quick response.
