Hi dear,
I have some question about ADC0_CH7 and ADC0_CH8 triggle dma request question in mpc574x. In my test,I try using ADC0_Ch7 and ADC0_CH8 EOC condition to triggle DAM transfer,pushing ADC0CH7 and ADC0CH8 CDR regist's result to indicate data buffer. But in my test, I find only one channel result is true ,other channel result in bad data. How should i change my configure to make ADC0_CH7 and CH8 transfer data is right. DMA use fix_prio and ADC0_CH7 prio == 7, ADC0_CH8 prio == 8
follow is my configure
ADC_0.DMAR0.B.DMA8 = 1;
ADC_0.DMAR0.B.DMA7 = 1;
ADC_0.DMAE.B.DCLR = 0;
ADC_0.DMAE.B.DMAEN = 1;
DMA_0.CR.B.CX = 0; //normal operate mode
DMA_0.CR.B.ECX = 0;
DMA_0.CR.B.GRP1PRI = 1; //Fixed priority arbitration
DMA_0.CR.B.GRP0PRI = 0;
DMA_0.CR.B.EMLM = 1; //enable minor loop mapping and disable offset
DMA_0.CR.B.CLM = 0;
DMA_0.CR.B.HALT = 0;
DMA_0.CR.B.HOE = 0;
DMA_0.CR.B.ERGA = 0;
DMA_0.CR.B.ERCA = 0;
DMA_0.CR.B.EDBG = 0;
DMAMUX_0.CHCFG[4].B.TRIG = 0; //设置adc0_ch8的dma通道
DMAMUX_0.CHCFG[4].B.SOURCE = 0x12;
DMAMUX_0.CHCFG[4].B.ENBL = 1;
DMA_0.ERQ.B.ERQ4 = 1; //open hardware request
DMA_0.TCD[4].SADDR.R = 0xFBE00120; //ADC0_CH8_CDR_ADD
DMA_0.TCD[4].ATTR.B.SMOD = 0;
DMA_0.TCD[4].ATTR.B.SSIZE = 2; //uint16
DMA_0.TCD[4].SOFF.R = 0;
DMA_0.TCD[4].SLAST.R = 0;
DMA_0.TCD[4].DADDR.R =(uint32_t) adc0Ch8Data;
DMA_0.TCD[4].ATTR.B.DMOD = 0;
DMA_0.TCD[4].ATTR.B.DSIZE = 2;
DMA_0.TCD[4].DOFF.R = 4;
DMA_0.TCD[4].DLASTSGA.R = -80; //只有在major loop 完成以后才执行这个步骤
DMA_0.TCD[4].NBYTES.MLOFFNO.B.SMLOE = 0; //minor loop enable and link-to-link disable
DMA_0.TCD[4].NBYTES.MLOFFNO.B.DMLOE = 0; //minor loop offset is applied to the SADDR
DMA_0.TCD[4].NBYTES.MLOFFNO.B.NBYTES = 4; //minor loop cnt
DMA_0.TCD[4].BITER.ELINKNO.B.ELINK = 0;
DMA_0.TCD[4].BITER.ELINKNO.B.BITER = 20;
DMA_0.TCD[4].CITER.ELINKNO.B.ELINK = 0;
DMA_0.TCD[4].CITER.ELINKNO.B.CITER = 20;
DMA_0.TCD[4].CSR.B.BWC = 0;
DMA_0.TCD[4].CSR.B.MAJORLINKCH = 0;
DMA_0.TCD[4].CSR.B.ACTIVE = 0;
DMA_0.TCD[4].CSR.B.DONE = 0;
DMA_0.TCD[4].CSR.B.MAJORELINK = 0;
DMA_0.TCD[4].CSR.B.ESG = 0;
DMA_0.TCD[4].CSR.B.INTHALF = 0;
DMA_0.TCD[4].CSR.B.INTMAJOR = 1;
DMA_0.TCD[4].CSR.B.START = 0;
DMAMUX_0.CHCFG[5].B.TRIG = 0; //设置adc0_ch7的dma通道
DMAMUX_0.CHCFG[5].B.SOURCE = 0x12;
DMAMUX_0.CHCFG[5].B.ENBL = 1;
DMA_0.ERQ.B.ERQ5 = 1; //open hardware request
DMA_0.TCD[5].SADDR.R = 0xFBE0011C; //ADC0_CH7_CDR_ADD
DMA_0.TCD[5].ATTR.B.SMOD = 0;
DMA_0.TCD[5].ATTR.B.SSIZE = 2; //uint16
DMA_0.TCD[5].SOFF.R = 0;
DMA_0.TCD[5].SLAST.R = 0;
DMA_0.TCD[5].DADDR.R =(uint32_t) adc0Ch7Data;
DMA_0.TCD[5].ATTR.B.DMOD = 0;
DMA_0.TCD[5].ATTR.B.DSIZE = 2;
DMA_0.TCD[5].DOFF.R = 4;
DMA_0.TCD[5].DLASTSGA.R = -80; //只有在major loop 完成以后才执行这个步骤
DMA_0.TCD[5].NBYTES.MLOFFNO.B.SMLOE = 0; //minor loop enable and link-to-link disable
DMA_0.TCD[5].NBYTES.MLOFFNO.B.DMLOE = 0; //minor loop offset is applied to the SADDR
DMA_0.TCD[5].NBYTES.MLOFFNO.B.NBYTES = 4; //minor loop cnt
DMA_0.TCD[5].BITER.ELINKNO.B.ELINK = 0;
DMA_0.TCD[5].BITER.ELINKNO.B.BITER = 20;
DMA_0.TCD[5].CITER.ELINKNO.B.ELINK = 0;
DMA_0.TCD[5].CITER.ELINKNO.B.CITER = 20;
DMA_0.TCD[5].CSR.B.BWC = 0;
DMA_0.TCD[5].CSR.B.MAJORLINKCH = 0;
DMA_0.TCD[5].CSR.B.ACTIVE = 0;
DMA_0.TCD[5].CSR.B.DONE = 0;
DMA_0.TCD[5].CSR.B.MAJORELINK = 0;
DMA_0.TCD[5].CSR.B.ESG = 0;
DMA_0.TCD[5].CSR.B.INTHALF = 0;
DMA_0.TCD[5].CSR.B.INTMAJOR = 1;
DMA_0.TCD[5].CSR.B.START = 0;
Thanks!
Hi, it'll be because the is only one DMA input trigger from ADC_0.
DMA module is not capable to distinguish which ADC channel triggers the DMA request as you have the same source assigned to both TCDs, thus both conversions triggers both DMA tranfers.
You should set up only one TCD for ADC_0 conversion.
