how to use trace debugger
edavis
I have a i-jet trace debugger pod. I have it connect to the standard J-TAG 20 connector (not a MIPI 20 pin). I would
like to use the SWO on the standard J-TAG connector per a 2925, but I have never done this before. Do I need to configure the ETM registers in order for the SWO to work? If so, do  you have example code?
