Using licensed version of codewarrior
sushantbanavali
Hello ,
I had installed evaluation version of codewarrior CWS12v5.2 about a month back.
I have obtained a license.dat file for using licensed version of codewarrior.
Kindly let me know the procedure of using licensed version of codewarrior.
Sushant Banavali
stanish
Hi Sushant,
1) backup the original (evaluation license) e.g by renaming the original file from:
c:\Program Files (x86)\Freescale\CWS12v5.2\license.dat
to
c:\Program Files (x86)\Freescale\CWS12v5.2\license_eval.dat
2)  copy the permanent license you obtained (license.dat) into
3) run CodeWarrior and check the permanent license has been accepted (CodeWarrior IDE V5.2: Does my license.dat work?)
Hope it helps.
Stan
