Board name imx6ulmg is not support
Question asked by Yafen Zhang on Nov 2, 2017
Latest reply on Nov 3, 2017 by Dhvanil Patel
Dear All,
When I run the below command, c. What board name should I use?
 MACHINE=imx6ulmg DISTRO=fsl-imx-x11 source ./fsl-setup-release.sh -b build-x11
 Build directory is  build-x11
The $MACHINE you have specified (imx6ulmg) is not supported by this build setup
Usage: source setup-environment <build-dir>
    <build-dir>: specifies the build directory location (required)
If undefined, this script will set $MACHINE to 'imx6qsabresd'.
Supported machines:
 imx23evk
 imx28evk
 imx51evk
 imx53ard
 imx53qsb
 imx6dlsabreauto
 imx6dlsabresd
 imx6qdlsolo
 imx6qpsabreauto
 imx6qpsabresd
 imx6qsabreauto
 imx6qsabresd
 imx6slevk
 imx6solosabreauto
 imx6solosabresd
 imx6sx14x14arm2
 imx6sx17x17arm2
 imx6sx19x19ddr3arm2
 imx6sx19x19lpddr2arm2
 imx6sx_all
 imx6sxsabreauto
 imx6sxsabresd
 imx6ul14x14ddr3arm2
 imx6ul14x14lpddr2arm2
 imx6ul7d
 imx6ul9x9evk
 imx6ulevk
 imx6ull14x14ddr3arm2
 imx6ull14x14evk
 imx6ull9x9evk
 imx7d12x12ddr3arm2
 imx7d12x12lpddr3arm2
 imx7d19x19ddr3arm2
 imx7d19x19lpddr2arm2
 imx7d19x19lpddr3arm2
 imx7dsabresd
 ls1021atwr
 twr-vf65gs10
 apalis-imx6
 cfa10036
 cfa10037
 cfa10049
 cfa10055
 cfa10056
 cfa10057
 cfa10058
 cgtqmx6
 cm-fx6
 colibri-imx6
 colibri-imx7
 colibri-vf
 cubox-i
 imx233-olinuxino-maxi
 imx233-olinuxino-micro
 imx233-olinuxino-mini
 imx233-olinuxino-nano
 imx6dl-riotboard
 imx6qdl-variscite-som
 imx6q-dms-ba16
 imx6qsabrelite
 imx6sl-warp
 imx6ul-pico-hobbit
 imx7s-warp
 m28evk
 m53evk
 nitrogen6sx
 nitrogen6x
 nitrogen6x-lite
 nitrogen7
 pcm052
 tx6q-10x0
 tx6q-11x0
 tx6s-8034
 tx6s-8035
 tx6u-8033
 tx6u-80x0
 tx6u-81x0
 ventana
 wandboard
To build for a machine listed above, run this script as:
MACHINE=<machine> source setup-environment <build-dir>
 ERROR - No build directory is set yet. Run the 'setup-environment' script before running this script to create  .
