How to flash image on Custom board lpc54618?
subodhmankar
I am able to use lpclink2 to debug my custom board.
But when I try to flash image using lpclink2, MCUXPRESSO IDE shows success but custom board doesn't get flashed.
What are the steps, tools and procedure I should follow to flash LPC54618 custom board?
Please provide me suggested links pr tools...
jeremyzhou
Hi Subodh Mankar,
for the opportunity to serve you.
1. Firstly, you should use the correct demo for testing, you can build a SDK for LPC54618 via the following link:
2. Secondly, compare with the OM13092 to check the hardware circuit of LPC54618 custom board.
TIC
