Is any solution to allow the EVK Board disply video/image with a HDMI interface/connector?
I bought a "MX-6SLL-EVK Board" to develope my eMMC-demo-board and want it displays video/image with a HDMI interface/connector.
However, the "HW User-Guide" of the EVK Board only lists the "LCD connector" as its display interface.
Please help clarify that because it's important for my project to display results on regular mointors or projectors.
Many thanks for your supports.
Albert
Hello Albert,
The i.MX6SLL EVK board does not have an HDMI connector. However, the HDMI daughter board may be used to get HDMI output (link below), as it is a converter from parallel LCD to HDMI. (Changes in the device tree may be needed, so it wouldn’t be a plug-and-play solution).
https://www.nxp.com/part/MCIMXHDMICARD?lang_cd=en
I hope this helps!
