Boot Mode iMX6UL
Question asked by Santhosh Ramani on Oct 27, 2017
Latest reply on Oct 30, 2017 by Santhosh Ramani
If the Fuses are set to boot from NAND and BOOT_MODE set to 00 with resistors - is it possible to change the BOOT_MODE to 01 via resistors even if the Fuses and programmed.
If yes, isn't this a security issue where in someone can change the boot mode, and boot from for eg. SD Card and read all the data from NAND.
Is there a way to prevent changing the Boot Mode once the Fuses have been programmed?
Thank you
Santhosh
