FS6520唤醒
FS6520唤醒
qianghu
我给FS6520的强制注入FCCU错误,发现SBC立马停止供电。重新上电后,必须用IO_0唤醒才可以正常供电。在正常喂狗的情况下,如果停止喂狗,SBC进入休眠后,断电,重新上电以后,也会出现必须用IO-0唤醒。请问重新上电不可以清除FS6520上次检测到的错误吗?重新上电不可以使FS6520脱离上次的休眠态吗?
      感谢大家解答我的问题,谢谢!
guoweisun
Thanks for your interesting in NXP products.
Please make sure after power off  8s then power on again to try.
qianghu
thank you ,My question has been solved.
