What is PCF5485 ?
What is PCF5485 ?
gilesrobinson
I have an evaluation board on which there is a chip marked with:
    COLDFIRE
    PCF5485CZP200
    L14S
    QL20433
Note PCF not MCF.
What is this?
Clearly I can find info on MCF5485, but not PCF5485.
gilesrobinson
Thanks for the information.  I'll be careful what I use it for, if anything.
miduo
Usually "PCF" are not completely qualified. Initial parts are PCF, after the first level of validation, they become "XCF". When they’re fully qualified, the parts become MCF.
TomE
Specialist II
Google found one from 12 years ago that didn't answer your question, but that's a hint. Searching this Forum for "PCF gets lots of hits.
https://community.nxp.com/message/115850
The above link says that designates a "prequalification" part. These are usually found on the earliest evaluation boards. They also have all of the uncorrected problems in the Errata, so you shouldn't be using them beyond initial product evaluation.
Tom
