the P2041 can not work up
hezhao
Helllo. The P2041 ' HRESET is always keep asserted ( low state) after the PORESET negated (high stase)  during power on reset fllow.Finally the P2041 can not work up.
ufedor
The issue could be caused by many factors, so it is required to thoroughly check the design.
Please consider creating a Technical Case to investigate the issue:
https://community.freescale.com/thread/381898
