Dear Sir
Customer want to stop(disable) and re-start(enable) the output data on LVDS bus(LVDS_TX0, LVDS_TX1, LVDS_TX2, LVDS_TX3 and LVDS_CLK).
I think that it is able to control with LDB_CTRL[chx_mode[1:0]].
Q1.
Can I dynamically change disable/enable by setting LDB_CTRL[chx_mode[1:0]]?
Q2.
When disabling the LDB Channel #0 Serializer, can I choose either LDB_CTRL[ch0_mode[1:0]] = 0b00 or LDB_CTRL[ch0_mode[1:0]] = 0b10?
Q3.
Is it enough to set LDB_CTRL[ch0_mode[1:0]] to 0b01 or 0b11 when re-enabling LDB Channel #0 Serializer?
Eishi SHIBUSAWA
Solved! Go to Solution.
I confirmed by using Sabre board.
It seems to be Disable for both LDB_CTRL[ch1_mode[1:0]] = 0b00 and 0b10 settings.
It seems to be able to dynamically disable and enable.
