We are designing a custom board with T2080 processor & planning to use SATA NANDrive device GLS85LS1016B(16GB).
Can any one let me know whether T2080 compatible to use with SATA NANDrive device(16GB) ?
Solved! Go to Solution.
The T2080 has two SATA controllers is compliant with the Serial ATA 2.6. As we can see SATA NANDrive provides the functionality and compatibility of a complete SATA hard disk drive (HDD). Hence the T2080 should be compatible with SATA NANDrive device (16GB).
