Firmware placement for EzPort
alexeyusoltsev
 Good day ladies and gentlemen,
I need help.
I've made project and a PCB (№2) that have to program main PCB(№1) through EzPort. For that purpose I am to make a firmware that contain firmware for itself and firmware for another board linked at curtain address(for board №1).
 So my question is how can I link existing *elf file into project to place it in the flash under known address?(for further upload to another board through EzPort)
P.S.: I've heard that some utilities can convert *elf/*bin to .c files that i can deal with. But I'd glad to learn other solution to the problem.
Alexey.
Tags (3)
mjbcswitzerland
Specialist V
Hi Alexey
You can use GCC "objcopy" to generate binary files from your elf files. Then you can use the uTasker utilities to combine them or to convert them to c files: http://www.utasker.com/forum/index.php?topic=1445.0
Tools and details at the link.
Also see the uTasker EzPort cloner that allows one board to clone another via EzPort:
http://www.utasker.com/docs/uTasker/uTaskerEzPortCloner.pdf
Mark
Kinetis: http://www.utasker.com/kinetis.html
Faster and cheaper project development....
alexeyusoltsev
 Hi Mark,
thanks for your interest and contribution!! I'll try to start with that.
Alexey.
