Dear support team,
We are working with S32K144 device. We want to latch the falling edges of signal coming on FTM0_CH1.
This signal is generated using FTM0_CH0 port. We want to configure FTM0_CH1 in such way that on falling edge
FTM_MOD counter value should be latched and not get reset. I tried to implement this using Global Base Timer
feature of FTM. I am unable to configure it properly and don't know how to read latched value using this feature
(As I am trying this for single module with 2 different channels). Please help us if it is possible to implement using GBT.
Sorry but I have difficulties to understand. Could you reformulate the question?
The GTB function allows synchronization of multiple FTMs, but you want to use just one FTM.
