S32K144 generate bin under MDK
shenlanzeng
How does S32K144 generate bin ,under MDK,how many addresses need to changed,thanks!
i used MDK generate bin like that,but it generate a floders
generate:
robertboys
I am no fromelf expert:  but using --bin creates a file for each load area - that is why you see the folder with 3 files.
Try this:  does it give you what you want ?
fromelf --bincombined --output=Blinky.bin Blinky.axf
You can also create a Intel hex file easily.
Bob
shenlanzeng
hi,i used BootLoader like that:it's a led code,i configed like that
and the jump command like that:
but after jump,Nothing happens,so could you help me,thanks!
shenlanzeng
shenlanzeng
thanks ,the problem has been solved
