How to complile, flash for a small application into the QorIQ LS1021A processor
Question asked by Ganesh Kimidi on Oct 12, 2017
Latest reply on Oct 23, 2017 by Pavel Chubakov
I am new to Embedded Linux and QorIQ LS1021A processor. I got the new board, when switch on the board, could able to see the below logs.
Trying to boot from MMC1
U-Boot 2016.05-TQMLS102xA-BSP-0100 (Jul 21 2017 - 21:45:13 +0200)
CPU:   Freescale LayerScape LS1021E, Version: 2.0, (0x87081120)
Clock Configuration:CPU0(ARMV7):1000 MHz,
Bus:300  MHz, DDR:1600 MHz (3200 MT/s data rate),
Reset Configuration Word (RCW):
00000000: 0610000a 00000000 00000000 00000000
2C:   ready
DRAM:  1 GiB
Using SERDES1 Protocol: 80 (0x50)
Booting from mmc ...
switch to partitions #0, OK
mmc0 is current device
MMC read: dev # 0, block # 8192, count 16384 ... 16384 blocks read: OK
MMC read: dev # 0, block # 4096, count 2048 ... 2048 blocks read: OK
boot device tree kernel ...
Kernel image @ 0x82000000
Booting Linux on physical CPU 0xf00
Linux version 4.4.0-TQMLS102xA-BSP-0100 (ingbfried@ingbfried-virtual-machine<mailto:ingbfried@ingbfried-virtual-machine>) (gcc version 4.8.3 20131111 (prerelease) (OSELAS.Toolchain-2013.12.2 linaro-4.8-2013.11) ) #38 SMP PREEMPT Fri Jul 21 21:43:42 CEST 2017
Questions:
1. Does the board has running Linux version 4.4.0-TQMLS102xA-BSP-0100?
2. I would like write a small apllication, how to compile & build the application & how to flash it into the board & what is the tool chain for Linux Ubuntu.
Thanks & Regards,
Ganesh kImidi
+91 9731968130.
If you are not the addressee, please inform us immediately that you have received this e-mail by mistake, and delete it. We thank you for your support.
