Hi, I'm now working on KL27Z256 with KSDK2.0.
My goal is to get 5ch data via ADC with DMA transfer.
I think 5*16bit ADC0-RA data should be stored in memory in a row, and ADC0->SC1 is switched automatically.
In my codes attached, only the first 16bit data is stored in memory even if ADC0->SC1 seems to be changed.
Unfortunately I haven't found any sample codes on the SDK and here.
Is there something wrong ?
Your any advice will be appreciated.
Original Attachment has been moved to: dma_peripheral_to_memory.c.zip
Thank you for your reply.
I have finally fixed the problem. I needed to change parameters for sc1.
Now, DMA doesn't work again after merging "usb cdc vcom lite" sample into the project but It should be another issue.
Hi, Shuichiy,
I think the solution is okay to use ADC to trigger DMA_CH0, then use channel link(DMA_CH1) to transfer adctable[] to ADC_SC1A to start another ADC conversion.
I think you have to use debugger to display the DMA register setting, especially DMA_DCR0 reg,the LINKCC bits should be 2b'10, the LCH1 bits should be 2b'01.
Pls paste the DMA register setting so that we can have a review.
Xiangjun Rong
