I am working on S32K144 EVB. Intentionally I am creating an error to check error handling. Only one time I am sending data. If I not connected to CAN bus, I am getting ACKERR, BIT0ERR, BIT1ERR. After hitting error handler
I am clearing all these errors . After clearing error also repeatedly hitting the handler.
Please help.
Thanks and Regards,
Ravi Ranjan.
I think you should upload you project.
Hi Jinshuai xu,
Thanks for reply. Actually that issue is solved. I was not clearing Overrun Error bit. After clearing that, it is not hitting handler repeatedly.
Thanks and Regards,
Ravi Ranjan.
