I am checking IMX7D internal temperature sensor section. (Section 14.2) in TRM version "i.MX 7Dual Applications Processor Reference Manual, Rev. 0.1, 08/2016". I found "Figure 14-3. High Level Temp Sensor System Diagram" is missing there. I downloaded the TRM from the below link.
i.MX 7Dual Arm Cortex-A7 Processor|NXP
I need to check for "High Level Temp Sensor System Diagram". Any help?
Gopinath S
Solved! Go to Solution.
The image will be added in the next RM release.
For the moment you can use this image as reference.
Diego
Diego
Any updates please?
