LPC1225 LED BLINKING PROGRAM NOT WORKING
dhineshe
Hi frnds,
i am trying to program led blinking in P0_30 using LPC1225/301 microcontroller . there is no error in this program. But led is not blinking. can anyone suggest me what is the problem in this program.
#include<lpc122x.h>
void delay(unsigned short int ms) ;
int main(void)
LPC_SYSCON->SYSAHBCLKCTRL |=(1UL<<31)|(1<<30)|(1<<29);
LPC_IOCON->PIO0_30 &=~0xFF;
LPC_IOCON->PIO0_30 |= (1<<4)|(1<<7);
LPC_GPIO0->DIR |= (1<<30);
LPC_GPIO0->CLR |= (1<<30);
while(1)
LPC_GPIO0->SET |= (1<<30);
delay(1000);
delay(1000);
unsigned short int j;
unsigned long i;
for(j=0;j<ms;j++)
for(i=0;i<1700;i++);
chrispflieger
Enable IOCON  along with the ports
LPC_SYSCON->SYSAHBCLKCTRL |=(1UL<<31)|(1<<30)|(1<<29) | (1 << 16);
Otherwise, monitor the pin with an Oscope - maybe the LED circuit is incorrect.
dhineshe
Thank you for your reply
As you mentioned, i reprogrammed
#include<lpc122x.h>
int main(void)
LPC_SYSCON->SYSAHBCLKCTRL |=(1UL<<31)|(1<<30)|(1<<29)|(1<<16);
while(1)
delay(1000);
delay(1000);
unsigned long i;
for(j=0;j<ms;j++)
still its not working even i checked circuit is correct i checked osc nothing.
converse
Senior Contributor V
Your delay function won't work as expected, as the compiler will optimise away your loops. Make sure you put 'volatile' on each of your variable declarations:
volatile unsigned short int j;
volatile unsigned long i;
See https://community.nxp.com/message/630584
dhineshe
Thank you for your reply my frnd,
I dont think its delay fault i just removed delay function  i am trying to program the P0_30 port pin for zero or clear
This program also not working. i dnt know what went wrong
#include<lpc122x.h>
int main(void)
while(1)
dhineshe
This program i got from internet this program work superbly
/******************** (C) COPYRIGHT 2010 Embest Info&Tech Co.,LTD. ********************
* File Name : main.c
* Author : Wuhan R&D Center, Embest
* Date First Issued : 10/15/2010
* Description : LED blinky example.
* History:
* 10/15/2010: V1.0
/* Includes ------------------------------------------------------------------*/
#include "lpc12xx_libcfg.h"
/* Private define ------------------------------------------------------------*/
/* Number of user LEDs */
#define LED_NUM 1
const unsigned long led_mask[] = { 30};
/* Private variables ---------------------------------------------------------*/
/* SysTick Counter */
volatile unsigned long SysTickCnt;
/* Private functions ---------------------------------------------------------*/
void SysTick_Handler (void);
void Delay (unsigned long tick);
* @brief SysTick handler sub-routine (1ms)
* @param None
* @return None
void SysTick_Handler (void) {
SysTickCnt++;
* @brief Delay function
* @param tick - number milisecond of delay time
* @return None
void Delay (unsigned long tick) {
unsigned long systickcnt;
systickcnt = SysTickCnt;
while ((SysTickCnt - systickcnt) < tick);
* @brief Main program body
* @param None
* @return int
int main (void) { /* Main Program */
int num = -1;
IOCON_PIO_CFG_Type PIO_mode;
//SysTick_Config(SystemCoreClock/1000 - 1); /* Generate interrupt each 1 ms */
SYS_ConfigAHBCLK(SYS_AHBCLKCTRL_GPIO0, ENABLE);
IOCON_StructInit(&PIO_mode);
PIO_mode.type = IOCON_PIO_0_30;
IOCON_SetFunc(&PIO_mode);
GPIO_SetDir(LPC_GPIO0, 30, 1);
GPIO_SetLowLevel(LPC_GPIO0, 30, 1);
for (;;) { /* Loop forever */
delay(500);
GPIO_SetHighLevel(LPC_GPIO0, 30, 1);
delay(500);
unsigned long i;
for(j=0;j<ms;j++)
#ifdef DEBUG
* @brief Reports the name of the source file and the source line number
* where the CHECK_PARAM error has occurred.
* @param file file Pointer to the source file name
* @paramline line assert_param error line source number
* @return None
void check_failed(uint8_t *file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while(1);
#endif
/* --------------------------------- End Of File ------------------------------ */
dhineshe
this program i worte myself but it is not working i used library #include<lpc122x.h> but not working error also zero
#include<lpc122x.h>
int main(void)
while(1)
dhineshe
this program is working
* History:
* 10/15/2010: V1.0
#define LED_NUM 2
const unsigned long led_mask[] = { 30,31};
* @param None
* @return None
SysTickCnt++;
* @return None
* @param None
* @return int
//LPC_IOCON->PIO0_30 &=~0xFF;
delay(1000);
delay(1000);
unsigned long i;
for(j=0;j<ms;j++)
#ifdef DEBUG
* @return None
/* Infinite loop */
while(1);
#endif
dhineshe
this program is not working
#include<lpc122x.h>
void delay(unsigned int ms);
int main(void)
while(1)
delay(1000);
delay(1000);
int i,j;
for(i=0;i<ms;i++)
for(j=0;j<1700;j++);
dhineshe
There is any different between the #include<lpc122x.h> and #include "lpc12xx_libcfg.h"
why my own program is not working.
kerryzhou
Hi Dhinesh E,
   You can compare these two headfile, check the details.
   Beside, you can debug your code, check the register, whether the according register is modified.
  Any further question, just let me know!
kerry
