Boot LPC4330 from SPI/SSP: what chips are supported?
gertvierman
I just found out that the LQFP144 package can only mux the I2S1 through the same pins which are needed for the SPIFI, which I currently use to boot.
Alternative would be to boot from SPI/SSP instead of SPIFI. Does anyone have experience with this, and what SSP/SPI chips are know to be compatible with the LPC43xx boot rom?
Carlos_Mendoza
Hi Gert,
We don't currently have a list of supported SPI flash devices, we have only tested QSPI. Compatability should be good with a wide range of SPI devices because SPI boot operates at a much lower speed.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
gertvierman
AT45DB161E boots successfully.
Carlos_Mendoza
Hi Gert,
It is good to hear that! thanks for letting us know.
Carlos Mendoza
gertvierman
Ok, thank you. I planned for the Atmel AT45DB161E on my board, I'll share my results here when I tested.
