Codewarrior 11.2.3 installation failed
vijaykumardesai
Hi, I am trying to install Codewarrior 11.2.3 on ubuntu 14.04. After untarring and executing the ./setuplinx.sh, i get a failure as
/home/vdesai/disk1/setuplinux.sh.2888.dir/jre/bin/java: 1: /home/vdesai/disk1/setuplinux.sh.2888.dir/jre/bin/java: Syntax error: end of file unexpected (expecting ")")
I get same error with both online and offline versions.
addiyi
Before starting the installation, read the README.txt and follow the steps according with your linux version.
Adrian
addiyi
Adrian
