I am using FS4500 SBC and it is interfaced with MPC5742P. I use the drivers from NXP for SBC code.
After POR or wakeup event, I correctly release FS0B using the API provided after 7 watchdog cycles. And I also see that Fault Error is also 0. I see that the API is called without any errors. But I don't see the signal on pin FS0B is still low. I probed and checked.
Any idea what could be happening?
Thank You,
Sagar
hello,
I have the same problem.Can you tell me how to deal with it.
Thanks!
