Hi Lucas.
In order to investigate your problem efficiently, could you please upload your demo project here? thus we can check the problem directly.
Jennie Zhang
hello friend, thank you very much for the help. For some reason, when my teacher went to look at the codewarriors error he just did not show up and compile normally.
Hi Lucas,
Good to know it.
Next time if you meet similar problem, first try to go to IDE menu "project", "clean...". Then build again.
Jennie Zhang
