error of s32k144's flash read and write
shenlanzeng
Hi,i'm debugging flash read an write,when i used "EraseAndProgram",single step is ok,but run at full speed ,it reset,would you help to find what the promble ,thanks! ps:  I  used external 5V to supply .
danielmartynek
How did you define the .MyRamCode section?
Please try the default ram section using:
__attribute__ ((section(".code_ram")))   // place the function below into .code_ram section
void EraseAndProgram(void);
shenlanzeng
thanks for your help,i tried it ,but it reset all the same
danielmartynek
Can you attach the project?
shenlanzeng
thanks for your help,do you have any example of bootloder under the MDK , thanks!
danielmartynek
I'm afraid we don't.
shenlanzeng
How to use MDK to generate bin,i used MDK generate bin like that:
but it generates a folder
can you tell me how to generate bin under MDK,thanks!
shenlanzeng
thanks for replay,the problem has been solved!
jinshuaixu
Contributor V
Hi, friend
      Maybe you are not close interrupt before operate flash.you can try that close interrupt before erase flash section ,and open interrupt in the end.
shenlanzeng
Thanks for your relplay,how do i use the register operation to close all the interrypts,and open the interrupts,i didn‘t find the relevant information!
thanks for your help!
jinshuaixu
Contributor V
#if defined (__GNUC__)
#define ENABLE_INTERRUPTS() __asm volatile ("cpsie i" : : : "memory");
#else
#define ENABLE_INTERRUPTS() __asm("cpsie i")
#endif
/** \brief Disable interrupts
#define DISABLE_INTERRUPTS() __asm volatile ("cpsid i" : : : "memory");
#else
#define DISABLE_INTERRUPTS() __asm("cpsid i")
#endif
shenlanzeng
hi,i have been closed all interrupt,then erase the flash ,and run at full speed,but the s32k144 reset again.
best regards!
