Qorivva: sizeof a structure with bitfields
pascalbrand
Using CodeWarrior for MCU, v10.7, on Qorivva target, I am not able to understand the size of the current structures: S1 has size 1 (not expected - I was expecting 4, following the section "21.4.6 Bitfields" of the documentation MCU_Power-Architecture_Compiler.pdf), wheras S2 has size 4 (as expected):
    struct S1 {
        unsigned int a: 4;
        unsigned int b: 3;
        unsigned char c:1;
    struct S2 {
        unsigned char c:1;
        unsigned int a: 4;
        unsigned int b: 3;
Could you elaborate?
Thanks for your support,
Pascal.
PS: I have attached the project to highlight it.
Original Attachment has been moved to: MPC-C.7z.zip
pascalbrand
Hello ZhangJennie‌,
could you have a look?
Pascal.
ZhangJennie
Hi Pascal,
I don't work for Qorivva.
I would suggest you create a private case to NXP support team directly it.
https://community.nxp.com/docs/DOC-329745?sr=search&searchId=356ea1f0-531d-4edb-b1aa-a707baa9ce8c&se...
Jennie Zhang
pascalbrand
Thanks a lot.
I've just created it as "NXP Support case #00136577".
Pascal.
