AN5201(Integrating the LIN driver) question
Question asked by BJ Hwang on Sep 19, 2017
Latest reply on Sep 24, 2017 by BJ Hwang
Dear Sir or Madam,
I'm using S12ZVMx128 EVB for testing LIN communication.
I use OSBDM port to debug the board and using AN5201SW for example.
The problem is the sw runs very well while OSBDM cable is inserted, but after reset(power switch off/on and the cable is removed), the motor is not running. It doesn't perform reset.
Could you give me some advice for this?
Thank you.
