It gets MPL3115A2R1 and finds that the part with below marking,
Marking: M3PR
FZ0D
Would you help to advise whether the above marking is correct?
Also what is the meaning of this marking?
Thanks a lot.
Hi Barley,
Yes, the above marking is correct.
The first line contains both part number code and assembly line code information.
The second line contains both date code and lot code information.
Tomas
