I am building the device tree for a custom board has an wl1835 wifi/bluetooth chip on it. I follow the instruction from Step-by-step: How to setup TI Wilink (WL18xx) with iMX6 Linux 3.10.53 , the wifi and bluetooth are not working. while I remove the kim and btwilink, the wifi works fine. (The st_kim, btwilink and wl18xx driver are enabled)
Edit:
How to enable second SDIO interface on Colibri iMX6 - Toradex Community
This fix seems to work for me.
hello Jason:
could you solve the WL1833 + IMX6Q ? I also follow the Step-by-step: How to setup TI Wilink (WL18xx) with iMX6 Linux 3.10.53, but the problem is always produced:
# ifconfig wlan0 up
wlan0: ERROR while getting interface flags: No such device
my kernel is 4.1.15,I also download TI R8.6_SP3 package and build result has no any error.
whenever I used .wlcore_sdio.ko or static mod into zImage (wlcore_sdio.o), the problem still is exist
So could you give me some suggestion ?
thank you!
Which version BSP and which board are you using?
