how can i have multi user on one port in tcp socket?
navidansari
hi
I have lpc1768 and  DP83848CVV  as Ethernet PHY
till now i open tcp socket on port 2000 and one user can connect to it and send and recieve data fine
TCP_sock = TCPOpenSocketOn(2000) ;
now I want to be able to connect more than one user
how can i do that?
Labels (2)
Tags (2)
soledad
Please check the below link and let me know if this helps,
tcp server example - | Mbed
Soledad
navidansari
not even close
soledad
Are you using LPCOpen?
navidansari
im using keil
