Hi All,
This is iMAX6Q based custom hardware design and I did DDR RAM calibration and updated the U-Boot with calibration values correctly. When I'm trying to load Yocto or Ubuntu it stuck as follows. Can you give any comment on this issue by referring following kernel logs.
Kernel log with Yocto---------------------------------------------------------------------------------------------
Kernel log with Ubuntu--------------------------------------------------------------------------------------------
Peter.
Hi Peter
one can try patch
https://github.com/Freescale/linux-fslc/commit/09845b886c1198c9461de424ffd95dde363324c1
or try to boot without hdmi in uboot.
In general, one can find place in code where kernel hanging using
AN4553 Using Open Source Debugging Tools for Linux on i.MX Processors
http://www.nxp.com/assets/documents/data/en/application-notes/AN4553.pdf
