Fatal Error[Li001]: could not open file
manmohanvishwak
I have downloaded software package from https://www.nxp.com/downloads/en/software/lpcopen_2_20_keil_iar_nxp_lpcxpresso_1549.zip
I am using IAR workbench. Now when I compile a sample code from ..\applications\lpc15xx\iar\nxp_lpcxpresso_1549\usbd_rom\hid_generic folder compiler shows and error
Fatal Error[Li001]: could not open file "..\software\lpc_core\lpc_board\boards_15xx\nxp_lpcxpresso_1549\iar_output\Exe\ C:\Users\MyPC\AppData\Local\Temp\EW4DED.tmp 1
Where to find this file ...how I can fix this..
jeremyzhou
Hi manmohan Vishwakarma,
for the opportunity to serve you.
I don't encounter this error as you pointed out, Fig 1 illustrates the version of IAR I used.
                                           Fig 1
                                                       Fig 2
TIC
