FlexCAN interface not working on i.MX 6SoloX M4 and A9
bowenzhang
I have the same problem as below
but his answer is not right for me。
The FlexCAN library worked perfectly and I was able to perform many tests on a CAN network,however,when  I wanted to get the A9 to boot the M4 automatically when the power switch was turned on,flexcan  can not get/send  message。
jasonqueenjimtrudeauMandardhaval
Labels (5)
Carlos_Musich
Hi Bowen,
Please look at the following thread. It is possible that A9 is reconfiguring clocks.
I.MX6 SoloX M4 Problem
Carlos
bowenzhang
I have  reconfig clocks
Carlos_Musich
Hi bowen,
I assume you have solved this problem. If this is the case we would really appreciate if you could share how did you solved this issue.
Carlos
bowenzhang
I have solved this problem,you can close this case for me and i will share myexperience later
