frame rate issue
Question asked by Muralikrishnan T on Sep 12, 2017
Latest reply on Sep 13, 2017 by igorpadykov
Hai;
currently i am working under imx6 processor with parallel camera module ,i done the camera interface and live streaming also,but only we got 15 fps as per my requirement i need achive minimum of 30 fps ,so kindly provided any solution to over come this problem and i tried using mxc out but its give QBUF and DQBUF .
i am using YUYV format to capture camera data and i converted to RGB24 using image converter ic  and i directly write into frame buffer fbo
