MPC5775k FFT
MPC5775k FFT
junyishen
I'm writing the FFT module for MPC5775k.I work only on the MPC5775k daughter board.S32 is V1.1.have some problems, can you help me see if my code is correct?I really need your help.
When my program runs to void SPT_FFT256_init(uint32_t twiddle_addr)which initializes twiddle factor and window factor.Everything is normal until the breakpoint is shown as shown in the diagram193654_193654.pngpastedImage_3.png
and then run, error.
I make sure that address of command_list,twiddle_addr and fft_window is a multiple of 8.as this
I really can't find where it went wrong,I tried to see the status register to find the error
I deleted some functions in order to exclude the possibility of other modules configuring conflicts, but I think the overall should be correct.I will give you my code.SDADC_save20170911.TXT is my save before deleting. Please help me and tell me what's wrong.
Jason YangMartin Kovar
YANG TIANXIronliu
Original Attachment has been moved to: main_Z4.c.zip
Original Attachment has been moved to: SDADC_save20170911.txt.zip
junyishen
I work on 2N76P,Does it have any effect?
