PN7150 Works as reader but not card emulation
nikmarkovic
We are using PN7150 on a custom board based on im6ul EVK connected to i2c. We have compiled the NFC library (--enable-pn7150) and the demo.
Using the demo app, we are able to read from an NFC tag and also rewrite it. However we can't get a Nexus 5X running Android 7.1.1 to read information from the controller when emulating a tag or in p2p mode. The phone is able to read the same tag, but does not react to our antenna, nor do we detect the phone. We have not tried a different phone yet.
We have tried tweaking the /etc/libnfc-nxp.conf to use CFG1 because we use 3.3V and no battery, and we have also also turning off standby - with same results. Our design is based on the reference design and we didn't spot anything deviating from it.
Does anyone have any pointers at where we should focus our troubleshooting?
Thanks!
Our part numbers are the following:
IC:
PN7150B0HN/C11002Y
Antenna:
ANFCA-5035-A01-IPEX
Log -- note that the log includes terminating the app with "enter" with some lines that look like errors, but otherwise looks normal.
/usr/sbin/nfcDemoApp share -t URI -u http://www.nxp.com
NxpExtns: find found NXPLOG_TML_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_FWDNLD_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_NCIX_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_NCIR_LOGLEVEL=(0x3)
NxpHal: Entering phNxpNciHal_init_monitor
NxpHal: Returning with SUCCESS
NxpTml: phTmlNfc_i2c_open_and_configure
NxpTml: Opening port=/dev/pn544
NxpTml: phTmlNfc_i2c_reset(), VEN level 1
NxpTml: phTmlNfc_i2c_reset(), VEN level 0
NxpTml: PN54X - Tml Reader Thread Started................
NxpTml: PN54X - Read requested.....
NxpTml: PN54X - Invoking I2C Read.....
NxpTml: PN54X - Tml Writer Thread Started................
NxpTml: PN54X - Tml Writer Thread Running................
NxpTml: PN54X - Write requested.....
NxpTml: PN54X - Invoking I2C Write.....
NxpHal: thread started
NxpNciX: len = 4 > 20000101
NxpTml: PN54X - I2C Write successful.....
NxpTml: PN54X - Posting Fresh Write message.....
NxpHal: write successful status = 0x0
NxpHal: Response timer started
NxpHal: Waiting after ext cmd sent
NxpTml: PN54X - I2C Read successful.....
NxpNciR: len = 6 > 400003001101
NxpTml: PN54X - Posting read message.....
NxpHal: read successful status = 0x0
NxpHal: Response timer stopped
NxpHal: Checking response
NxpNciX: len = 3 > 200100
NxpNciR: len = 28 > 40011900031E030008000102038081828302D002FF020004881001A0
NxpHal: NxpNci> FW Version: 10.1.a0
NxpExtns: find found NXP_I2C_FRAGMENTATION_ENABLED=(0x0)
NxpNciX: len = 6 > 20030301A005
NxpNciR: len = 9 > 4003060001A0050100
NxpHal: phNxpNciHal_print_res_status: response status =STATUS_OK
NxpHal: i2c_fragmentation_status existing
NxpFwDnld: Allocating Mem for Dnld Context..
NxpFwDnld: @@@libpn7150_fw.so
NxpFwDnld: NULL handler : unable to load the library file, specify correct path
NxpFwDnld: FW Image Length - ImageInfoLen 0
NxpFwDnld: FW Image Info Pointer - pImageInfo 0
NxpFwDnld: Image extraction Failed - invalid imginfo or imginfolen!!
NxpFwDnld: Error loading libpn54x_fw !!
NxpHal: FW version for FW file = 0x0
NxpHal: FW version from device = 0x1001a0
NxpFwDnld: Freeing Mem for Dnld Context..
NxpExtns: find found MIFARE_READER_ENABLE=(0x1)
NxpExtns: find found NXP_ACT_PROP_EXTN=/
NxpNciX: len = 3 > 2F0200
NxpNciR: len = 8 > 4F02050000009F97
NxpExtns: find found NXP_SYS_CLK_SRC_SEL=(0x1)
NxpExtns: find found NXP_SYS_CLK_FREQ_SEL=
NxpExtns: find found NXP_SYS_CLOCK_TO_CFG=(0x1)
NxpFwDnld: gphNxpNciHal_fw_IoctlCtx.bClkSrcVal = 0x1
NxpFwDnld: gphNxpNciHal_fw_IoctlCtx.bClkFreqVal = 0x0
NxpFwDnld: gphNxpNciHal_fw_IoctlCtx.bClkFreqVal = 0x1
NxpFwDnld: Clock frequency value is wrong in config file, setting it as default
NxpNciX: len = 10 > 20030703A002A003A004
NxpNciR: len = 17 > 40030E0003A0020101A0030108A0040101
NxpNciX: len = 8 > 20020501A0030108
NxpNciR: len = 5 > 4002020000
NxpHal: phNxpNciHal_check_factory_reset file not present = /data/nfc/nfaStorage.bin1
NxpNciX: len = 26 > 20021702A0EA08FFFFFFFFFFFFFFFFA0EB08FFFFFFFFFFFFFFFF
NxpExtns: find found NXP_NFC_PROFILE_EXTN=     D
NxpNciX: len = 8 > 20020501A0440100
NxpHal: Performing TVDD Settings
NxpExtns: find found NXP_EXT_TVDD_CFG=(0x1)
NxpExtns: find found NXP_EXT_TVDD_CFG_1=
NxpNciX: len = 10 > 20020701A00E03020900
NxpHal: Performing RF Settings BLK 1
NxpExtns: find found NXP_RF_CONF_BLK_1=  £     5 ô     D 
NxpNciX: len = 166 > 2002A313A00D0604359001F401A00D06064401900300A00D060630B0011000A00D0606420200FFFFA00D03063F04A00D0620428800FFFFA00D0422442200A00D06222D50340C00A00D063242F800FFFFA00D06342D24370C00A00D06343386800070A00D0434442200A00D06422D15450D00A00D0446442200A00D06462D05590E00A00D0644428800FFFFA00D06562D059F0C00A00D0654428800FFFFA00D060A3380860070
NxpHal: Performing RF Settings BLK 2
NxpExtns: find found NXP_RF_CONF_BLK_2=       W3
NxpNciX: len = 24 > 20021501A01D115733141700AA850080552A040063000000
NxpHal: Performing RF Settings BLK 3
NxpHal: Performing RF Settings BLK 4
NxpHal: Performing RF Settings BLK 5
NxpHal: Performing RF Settings BLK 6
NxpHal: Performing NAME_NXP_CORE_CONF_EXTN Settings
NxpExtns: find found NXP_CORE_CONF_EXTN=     ^   @
NxpNciX: len = 12 > 20020902A05E0101A0400100
NxpNciX: len = 6 > 20030301A085
NxpNciR: len = 12 > 4003090001A0850450082800
NxpExtns: find found NXP_CORE_STANDBY=/
NxpNciX: len = 4 > 2F000101
NxpNciR: len = 4 > 4F000100
NxpExtns: find found NXP_CORE_CONF=  + (
NxpNciX: len = 46 > 20022B0D2801002101003001083101033304010203045401065001025B010060010E80010181010182010E180101
NxpNciX: len = 10 > 21010700010103000105
NxpNciR: len = 4 > 41010100
NxpNciX: len = 16 > 21000D04040302050303800180030201
NxpNciR: len = 4 > 41000100
NxpNciX: len = 4 > 22000101
NxpNciR: len = 5 > 4200020001
NxpNciR: len = 8 > 6200050101010100
NxpNciX: len = 9 > 200406030101020101
NxpNciR: len = 7 > 40040400FF0103
NxpNciX: len = 5 > 0300028103
NxpNciR: len = 6 > 600603010301
NxpNciR: len = 5 > 0300028180
NxpHal: > Going through workaround - set host list
NxpHal: > Going through workaround - set host list - END
NxpNciX: len = 8 > 03000581010302C0
NxpNciX: len = 14 > 03000B81010101EA1401FCE91401
NxpNciX: len = 5 > 2201020101
NxpNciR: len = 4 > 42010100
NxpNciR: len = 8 > 6200050202018000
NxpNciX: len = 6 > 030003810204
NxpNciR: len = 6 > 030003818000
NxpExtns: find found NXPLOG_NCIHAL_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_EXTNS_LOGLEVEL=(0x3)
NxpNciX: len = 20 > 2101110003010300410401030041A00103000105
NxpNciX: len = 26 > 20021701291446666D010111020207FF03020003040164070103
NxpNciX: len = 19 > 20021005320120300104310100380101500100
NxpNciX: len = 8 > 200205010002F401
NxpHal: > Polling Loop Started
NxpNciX: len = 22 > 21031309000101010201030105018001810106017001
NxpNciR: len = 4 > 41030100
NxpNciR: len = 4 > 61070101
NxpNciR: len = 4 > 61070100
NxpNciR: len = 15 > 61050C01020480FF01008000000180
NxpHal: NxpNci: RF Interface = ISO-DEP
NxpHal: NxpNci: Protocol = ISO-DEP
NxpHal: NxpNci: Mode = A Passive Listen
NxpNciR: len = 5 > 6106020101
NxpNciR: len = 5 > 6106020302
NxpTml: _i2c_write() errno : 5
NxpTml: PN54X - Error in I2C Write.....
NxpHal: write error status = 0x1ff
NxpHal: write_unlocked failed - PN54X Maybe in Standby Mode - Retry
NxpNciX: len = 4 > 21060100
NxpNciR: len = 4 > 41060100
NxpNciX: len = 10 > 20020702310100380101
NxpNciX: len = 4 > 20050103
NxpNciR: len = 4 > 40050100
NxpNciX: len = 10 > 21030703800181018201
NxpNciX: len = 4 > 20000100
NxpNciR: len = 6 > 400003001100
NxpHal: Terminating phNxpNciHal client thread...
NxpHal: NxpNciHal thread stopped
NxpTml: PN54X - read request NOT enabled
NxpTml: PN54X - Write request NOT enabled
NxpTml: bThreadDone == 0
NxpHal: phNxpNciHal_close - phOsalNfc_DeInit completed
NxpHal: Failed to deallocate (list empty)
NxpHal: Node dump:
NxpHal: Node dump:
Tags (2)
IvanRuiz
Please go to the project properties -> C/C++ Build -> Settings -> Preprocessor, there define the symbols you need (P2P_SUPPORT, RW_SUPPORT, CARDEMU_SUPPORT).
I hope this helps!
Ivan.
nikmarkovic
Hi Ivan,
Are you are maybe confusing the question with another project? I searched the whole NFC library, demo code and kernel source for all three strings/defines and none are coming up. Which source are you referring to?
I am doing the following:
  • Downloading the kernel driver from git://github.com/NXPNFCLinux/nxp-pn5xx.git and adding it to the kernel. (that part seems to work because communication works).
  • Downloading git://github.com/NXPNFCLinux/linux_libnfc-nci.git
  • Cross-compiling the code on Linux with
    ./configure --host=arm-linux-gnueabihf --prefix=/usr --sysconfdir=/etc --enable-pn7150
  • Installing the demo on imx6ul
  • Running the demo code with /usr/sbin/nfcDemoApp poll << this part works
  • Running the demo code with /usr/sbin/nfcDemoApp share -t URI -u http://www.nxp.com<< this doesn't work.
Thanks!
Nik
