read eeprom with codewarrior
thorstenmumm
Hey,
it's possibel to read and write eeprom datas with codewarroir ?
i will read my config out of the eeprom and write it back with the next update of my firmware
my modul lerns same aktion by using it and i will not lost this information and it will be god when i can write datas direkt to the eeprom by flashing the Modul.
I youse the 9S12ZVC
thanks for help
thorstenmumm
Hello Jennie,
thanks, thats what i am loking for.
but now i  have the problem to reset the Controller by an CAN-MAssage.
What is the comand in Asm to restart the controller with an Reset.
asm (RESET);
CPMUARMCOP = 0x00;
dosent work and wehre i can find a tabel with the temperatur i get by the converterfunktion?
I dont find it in the Datasheet
Thorsten
ZhangJennie
Hi Thorsten,
It looks like now you asked new question about reset controller.
May I suggest you create a new thread for this new question?
Please post this new one to S12/MagniV MCU space:
https://community.nxp.com/community/s32/16-bit
We have MCU expert monitor this space. Thanks for your support.
Jennie Zhang
thorstenmumm
hi Jennie,
sorry, i had to work on a other Projekt last time. But now it goes on with this
Thats not what i mean.  At Microchip you can read and write the EEprom on the chip with the tool. So you can control what you controller had written or you can write spezial start defines
ZhangJennie
Hi Thorsten.
EEPROM is read-only space.EEPROM data can be read out in debugger but can not be written with debugger tool.
See attached video of how to read EEPROM data from debugger.
Jennie Zhang
ZhangJennie
Hi Thorsten
I recommend you refer this demo code. It should help you.
S12Z EEPROM example code
Jennie Zhang
